Gebrown wrote:
This is getting very frustrating! I have an upset wife because I won't get the Coachmen 301.
What will my truck haul??? I'm sick of looking so recommendations are appreciated. I'm sure most of you know but just in case.
Ram 1500, 5.7, 3.92 gears, 6" lift, 35" tires.
She wants a toy hauler with a door to the garage. However, we'll look at TTs as well if my truck can pull it.
35" tires are about 20% taller than the stock 29" or so tall tires.
That does not help. Also if your truck is a 1990, it will not have enough HP, so give it up. BTW What year is it, what engine? ANY idea of the horsepower? Is it a 3 speed, 4, 5 6, 8 or 9?
A travel trailer is sort of a requirement with a 1/2 ton truck, and probably most 3/4 ton trucks will not tow a heavy fifth wheel very well, so best to jump up to a 1 ton truck if you are planning on using a fifth wheel.
You can use the gas engine, and it will provide enough HP to move a 11,000 pound trailer in a 3500 series truck with a 4.10:1 rear end ratio and stock diameter tires. With the oversized tires, then 4.56 or higher number rear end gears would be required, unless you have a 5 or 6 speed transmission, and can downshift to a low enough gear to run 60 MPH at around 2,500 - 2,800 RPM's.
At 2,500 RPM, your engine will make sufficient horsepower to keep the 14,000 pounds moving down the road, and going up slight hills. By downshifting another gear, you will reach say 3,200 RPM, and have plenty of HP to make it up a mountain.
But it all depends on the model year of your truck, engine size, transmission, ect. Thanks for the help that you gave, but still . . .
Fred.
