- bkirkpatrickExplorer
nayther wrote:
1L243 wrote:
Back out in the RV today getting another winter project done. My Rig did not come with a heater vent in the bathroom. I could see that the heater duct for the bedroom ran right through the bathroom vanity. So I bought what I needed to put in a heater vent.
One concern though is getting very much air out of your newly added vent. You used a straight T fitting, should have been a "T-Wye" fitting, kind of looks more like a Y than a T. If you have both vents wide open you might not get much air into the bathroom as there's more pressure drop there than straight through. But then again you don't need as much air in a small bathroom so it might just work out O.K. I bring this up as HVAC is my business.
C'mon now. The bathroom? This is a very small space and the back pressure from the bedroom will provide more than enough heat to the bathroom. - 1L243Explorer III tested the furnace today and found that the volume of air coming out of the bathoorm and bedroom vent are pretty much the same. Closing off the bedroom vent doubled the volume coming out of the bathroom vent. I think it's going to work pretty well...
- 1L243Explorer III considered that so, I replaced that bedroom heater vent with a adjustable one that I can completely close off or adjust so adequate flow goes into the bathroom. At night when sleeping I can reverse that. The Y instead of a T would have been a good idea...
- offtohavasuExplorer
I was thinking the same thing. I'm even more anal, I would have included a damper going to the bathroom as well. - naytherExplorer
One concern though is getting very much air out of your newly added vent. You used a straight T fitting, should have been a "T-Wye" fitting, kind of looks more like a Y than a T. If you have both vents wide open you might not get much air into the bathroom as there's more pressure drop there than straight through. But then again you don't need as much air in a small bathroom so it might just work out O.K. I bring this up as HVAC is my business. - bkirkpatrickExplorerGreat Modification and great pictures. Nicely done.
- 64thunderboltExplorer IINice job. You will like it.
- 1L243Explorer IIBack out in the RV today getting another winter project done. My Rig did not come with a heater vent in the bathroom. I could see that the heater duct for the bedroom ran right through the bathroom vanity. So I bought what I needed to put in a heater vent.
4" T
4" Ducting
4" couplers
2 4" adjustable heater grills
metal duct tape
The ducting in the vanity
Splice into the ducting add couplers
Add T and connect duct
Drill hole for heater grill
Attach ajustable grill
I also added a adjustable grill to the bedroom heater vent where if needed I can close off part of the bedroom to force heat to the bathroom - 1L243Explorer IIYou are right about that. I took that photo from my photo library and was not paying attention. I corrected the connection when someone else pointed it out.
This is how its suposed to look
- BoonHaulerExplorer
1L243 wrote:
Your batteries are not balanced. You're going to destroy that lead battery. You need to move the negative lead to the opposite end battery post and that will balance your battery bank.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
