- BedlamModeratorYou were fortunate with your damage. My Weekend Warrior skirt shattered when my tire failed. Luckily it was covered by Les Schwab since they provided the tires.
- lincsterExplorer
Had a blowout on my trailer going to the dunes this weekend and damaged my fender a little.
Fixed the next day!!!!!
Didn't think I would ever see this. Michelin XPS Ribs. Tires were 4 1/2 years old. Always checked tire pressure before going. Park under covered parking and park on wood. - jneubigExplorerI added jackknife sofas to the toy hauler section. Picked them up on eBay. I have no idea why the manufacturer put the side wall to side wall setup from the factory. Here are some before and after pics.
- ORbikerExplorerI also got the pump off the floor with a little foam.
Mod Edit: Please do not post photos larger then 800x wide as it skews the forum for other readers. Thanks. - ORbikerExplorerI have been reading about others having freezing problems so I looked in the underbelly of my toyhauler.
I have a 2016 380TH. I don't know if all the Grand Designs are the same, but I found this today in the storage bay behind the removable wall.
The 2" vent pipe going to the plumbing station has a bad kink in the flexible venting. ---See arrow---
The fix was to reroute the vents to different ports in the main furnace plenum.
I found another kink in a bit further.
The fix was to disconnect the venting from the plenum and reroute it through the triangle gusset to the right. It might have taken 2 minutes and gives a better flow to the venting.
Mod Edit: Please do not post photos larger then 800x wide as it skews the forum for other readers. Thanks. - StraboExplorerBlue LED's is our theme also. Camp pole marker and step lights.
Light Bling :) - ORbikerExplorer
N-Trouble wrote:
Do those front cap LEDs serve any purpose or just for looks/bling?
There are a great nightlight out front. There's a strip on the frame rail on both sides in the front too. Blue LED's in the stair cases too.
Bling might help me fine my home in the dark too. - LKHAExplorer
Bing here haven't found anything else yet - VulcanmarsExplorerFilled up the propane tanks and made sure everything propane powered fired up. Going camping soon.
- nfa1eabExplorerDrained all the water out of the fresh and hot water tanks. Blew out all lines and put some antifreeze in the drain traps. Going to get down in the teens in the next few days and want the Road Warrior to be ready. Next trip is to the Rolex 24 in Daytona the end of the month.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
