fornost's avatar
fornost
what glue or adhesive to glue new paneling over the old
I am putting new panneling into my 93 nomad 5th wheel, I am wondering what would be some good glue/adhesive to use to glue new paneling over the old stuff.
The wall frames are aluminum or some kind of metal. and the walls have styrofoam in them, ceiling and roof have the pink insulation and are wood beams.
Trailer had a ton of water damage, both floors in slideouts were rotten and you would fall through them it was so bad. I have repaired the floor, the old paneling looks horrible.
I tried removing some of the paneling from the walls but it is all glued to the walls and tears up the styrofoam. so I stopped doing that after messing with one pannel.
The last trailer that I replaced paneling in I used nails, and eventually more moisture got to the walls and they started to bow just a little bit here and there, I think if I glued the new paneling in, it would be more flat and attached so that it wouldn't bow so easily.
I got new 5mm wood paneling that I am going to put in the trailer http://www.homedepot.com/p/t/203183010
just need to figure out what a good product would be to glue it in place.
  • Make sure they have the large gun needed for that size tube.
  • Awesome thanks for all the suggestions. I will look for the liquid nails.
    Looks like the best deal is the 28oz heavy duty at either home depot or lowes.
  • So is his original panel, so I see no problem! Chris
  • If you use Liquid Nails don't ever plan on removing your new panels. Once you use that stuff, they'll be there to stay.
  • Construction adhesive "Liquid Nails" is the best solution. There are plenty of choices, Loctite makes several instant grab types that work on wood, metal, styrofoam, fiberglas tub surrounds, etc, that dry clear so you can use plenty of adhesive at the seams.
  • You can buy panel cement, it comes in tubes for a calk gun. Liquid nails brand will have some as well as other brands. If you are doing a lot of this buy a good calk gun not one of the cheap ones. You will save yourself a lot of aggravation and bad language....heh.
    Liquid Nails
    get it locally tho at Home Depot or Lowes.
