greende
Jul 04, 2013Explorer II
goukcats wrote:
Kinda on the same subject... I am having a box & wiring installed for a double pole 220 outlet for a hot tub. I already have a 30 amp plug for my 5er but was wondering if I could use the same wire (hot tub wire) also for a 50 amp RV box. I assume I couldn't use both at the same time but would that work? Thanks...
If you're feeding the hot tub with a 50 amp breaker you could do it with some electrical management. You probably would need to turn the temp down to be sure you didn't draw too much power. 50 amps is 50 amps no matter where it goes. Your electrician would have to decide if it meets code, however. Good luck.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
