mhooker32's avatar
mhooker32
generator/welder issue.
miller generator/welder. at 1800 rpm, the generator portion should output 60 hz, 120v. . its 4 pole. output is 65v at 40 hz.. will output 60hz and 120v at about 3400 rpm. . the welder portion is a separate stator, it also outputs half the voltage and HZ. i suspected a bad pole on the rotor,. as a half assed test, i applied 12v to the slip rings. inserting a thin welding rod at each pole showed the same magnentic attraction. i was expecting a dead pole. . ohms out at 18 ohms, which is correct. on the 240 volt plug, i get read 60 v, 40hz from one leg to neutral or ground, . 120v and 40hz from hot to hot. . . runs like a 2 pole unit. im really stuck . . i ran it at 3400, and i get 60hz, but thats way to high rpm. for a moment, i saw the fluke spike to 130hz, but when i set it to min max it didnt do it again. . i can send a schematic. the fact that it has a generator stator and a welder stator that has the same issue makes me think its somehow the rotor. if it is, its a goner. i hope not. it spent a lot of time getting it to run like a top, now this. any thoughts?
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
