sdetweil
Sep 22, 2013Explorer
greende wrote:
Sorry this happened to you. I don't have any words of wisdom except to begin checking everything with your multimeter and add up the damage. Stay in touch and let us know. To my knowledge the combined neutral & ground together is no longer recommended for new installations like Dryers and welders but someone who has bought a new welder recently may be able to confirm this. If you had a four wire welder outlet, an RV would run off it with the appropriate adapter as the ground & neutral are separate.
thanks.. my welders are all 3 wire. as are the air compressors.
I find this interesting as the common and ground are bonded at the panel. but there was nothing on the common leg for the rv service.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
