Atom_Ant
Sep 25, 2013Explorer
sdetweil wrote:It IS 50A 220VAC service, just because the RV only happens to use 110V equipment, doesn't mean its not 50A 220VAC.john&bet wrote:jeepman71 wrote:DON'T DON'T do it unless it has 4 poles or hole in the outlet. YOU MUST have a NEUTRAL period.
I am currious, if my rv were a 50amp system and I plug into a 220V welder or dryer outlet what will I find? What different circuits or equipment would likely be damaged?
Let's assume that this rv is a very late model like a 2012.
I don't have to worry because mine is only a 30amp.
right. this is 50 amp 110v service.. requires a neutral..
NOT 50 amp 220 service.
What you are saying is incorrect, as when limiting in term to only 110VAC, it actually produced 100A.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
