- Atom_AntExplorer
Likes to tow wrote:
it is a normal 220 outlet, so he did something else wrong. Working construction for years doesn't make you an electrician.
A friend of mine wired up his own electrical outlet for his new motor home. He had worked construction for years and just thought it was a normal 220 volt outlet. He destroyed nearly all systems in the coach including the tv. The brand new motorhome went back to the dealer for nearly a month to get it all fixed. - A friend of mine wired up his own electrical outlet for his new motor home. He had worked construction for years and just thought it was a normal 220 volt outlet. He destroyed nearly all systems in the coach including the tv. The brand new motorhome went back to the dealer for nearly a month to get it all fixed.
- jdogExplorerIf you think it's O.K. to plug into a 220 plug then by all means do it. You will find out what happens like the genius OP did!
- Atom_AntExplorer
relaxin wrote:
relaxin is right. You should know that lostinaz! A lot of your Montana buds hooked up 220 volt dryers in their rigs by rearranging the two 20A 110 oulets provided.LostinAZ wrote:
Jim and Barb wrote:
RGordon is absoulty right! I have been an Industrial Maintenance Supervisor for 10 + years. All it is 220 single phase its only two 110 legs with a ground wire where it ties on a buss bar in the box that is also a tie point for your nuteral on a 110 v circut. The AMP rating is how much draw it it can handel while working 30 AMP is normal for a house.
What isn't being mentioned when we discuss two 110 V legs is they have to be out of phase to create 220V service. My understanding is that the 50 Amp service we hook into at RV Resort/Park pedestals, the two 110V 50 amp legs are not out of phase and therefore 220V is never present inside the RV.
WRONG!!!!
it is both hot legs, it has to be to only have one neutral and in electrical circuitry is referred to as a shared neutral, that in itself only carries the imbalanced load from the 2 hots
example hot #1 is carrying 10 amps, and hot#2 is carrying 15 amps, the neutral only carry's the difference of 5 amps
if you put both hots on one side of the service and lets say you draw on hot#1 35 amps, and hot # 2 you draw another 30 amps, with both hots on the same leg of the service you will have all the current combined on the neutral so 65 amps,,,, dam why is that wire getting so warm
The reason all the RV equipment is 120 volt is so the RV cam function when plugged into with an adapter a 30 amp outlet, the manufacturers realized early on when 50 amp was introduced that it would be a long time before a majority of parks have 50 amp outlets, so most of the time your 220v equipment would never be able to use if you only came across parks with 30 amp - relaxinExplorer
WRONG!!!!
The reason all the RV equipment is 120 volt is so the RV cam function when plugged into with an adapter a 30 amp outlet, the manufacturers realized early on when 50 amp was introduced that it would be a long time before a majority of parks have 50 amp outlets, so most of the time your 220v equipment would never be able to use if you only came across parks with 30 amp - sdetweilExplorerRCMAN, I will now use some testing/isolation device on every hookup.
I purchased the Progressive SSP-50 surge suppressor and circuit tester.
it specifically tests for open ground and neutral. I will not plug the trailer into my new circuit until I get the tester, and it says all is good. One time is enough. Only thing not tested yet is the A/C units.
Everything else is working ok - sdetweilExplorer
john&bet wrote:
sdetweil wrote:
Bonding refers to the ground(green/bare and neutral/white) being tied together in the panel such as a jumper from the neutral bar to the panel metal or a wire from the neutral bar to the green bar. Metal conduit does not do this, it will only act as a equipment ground(green/bare) and no ties to the neutral. In your sub panels the green/bares and neutral/whites need to be on separate bars. Hope this helps.
while not on topic, this incident has made me take a close look at both my subpanels, and both are a mess. ground and neutrals mixed, one enclosure not even grounded.. fun things to fix!
only thing I don't understand, sub panel using plastic conduit,
master has ground/neutral bonded. sub not bonded.
if the conduit had been metal, the sub panel would have inherited the bonding.
what can/am I supposed to do about this?
bond at the sub (no/no)
leave unbonded (maybe?)
helps, and thanks RCMAN.. (even in the text of this topic, the question/answers are conflicting. There is an 'assumption' by some, that a 'welder circuit' has a neutral. which it normally doesn't).
I have never seen a 220 circuit with a neutral except a dryer, which wants 110 for the electronics.
my subpanels will have them separated (one does, one doesn't as I type this, will be fixed later today). - john_betExplorer II
leave unbonded (maybe?) - RCMAN46ExplorerLets take it a little easy. Sdetweil was willing to tell us what happens if you connect to a 220 service with no neutral. Something that can happen to all of us that have 50 amp RV's and happen to connect to a source with an open neutral. Open neutrals are common in the power distribution system.
The RV if wired correctly will not have a connection between the neutral and ground. This will result in high voltages on the 110 gear depending on the impedance seen on each side of the 220. If one side is low impedance and the other is high the high side impedance can see as much as 200 plus volts. Then when that device fails it will become a low impedance and the other side will see high voltage. This will go on until most of the devices that are connected and turned on fail.
It is important to check out the park connection before connecting the RV. More so with the 50 amp connections due to the possible open neutral. - I want to know how much effort was taken to make the 50 push into the 60.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 27, 2025
