Nevadastars
Jun 23, 2017Explorer
Cummins12V98 wrote:Nevadastars wrote:
I am also in the Andersen Ultimate rail camp. Had a Husky slider when I first got the fiver and it was a PITA in comparison, and could not remove it from the truck without help. The Andersen is so simple it's ridiculous and I can connect and disconnect from inside the truck with the remote for the landing gear.
Easy to see from inside the truck to line it up. I had to get out several times with the old hitch if I was alone. The only reason to get out of the truck now is to push in the cable t-handle that is mounted on the fiver overhang and plug in the lights. I giggle every time I use it.
You don't get out to pull the cable?
Not when I load it because it was already out from the last time I disconnected it. :B
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
