23mikey
Mar 16, 2017Explorer
Old Buscuit has his springs mounted under the axle. My springs are on top of the axle,so I purchased a spring perch (see pic in post above), place in under the spring between the u bolts and jack from there.. Using the spring perch this way keeps from concentrating the weight in one spot on the axle, instead it spreads the weight around the circumference of the axle tube.
Mike
Mike
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
