0rion
Oct 28, 2014Explorer
what is this? (landing gear related)
I'm not exactly sure what this is or what it's purpose is. It has a wire coming off the battery, one to what I assume is the inverter, and the other to the landing gear switch. Is it just a junction so the gear will run from the battery or inverter? I think I'm having an issue due to it. My landing gear will sometimes stop for a second and start again. I had this problem a while back and thought I had it licked by pumping a few shots of grease into the zirx fittings on the legs. I now think it's related to this doomaflatchey. Also, when on 12v power sometimes the 12v will cut out and back on immediately...similar to what the legs are doing. Makes sense that they could be related since they both wire to this doomahickey. Trying to decide if the doohickey is bad or perhaps I have a battery with a bad cell or something. Battery seems to do fine as far as charging and holding a charge though which is why I'm starting with this.
