JIMNLIN
Feb 13, 2017Explorer III
Kinda what tireman9 says in his rv tire safety blog where he talks with a TRA engineer about the need for ST tires to have their capacity reduced up to 25%.
Tireman9 says;
**Finally chased down the answer. Getting to the bottom was a challenge because I ran into "customer service" people who could read from a script but had no idea why they were giving me the answer they were.
Even got to an engineer at Tire & Rim Association and based on his answers it was obvious TRA had not thought about ST type tires or the unique nature of most RV trailer applications for many years so I believe he acted a little surprised when I identified the engineering analysis that indicated that the current loads too high for many trailers and that the load capacity should be decreased by 15% to 25% or more if the failure rate was to be decreased to a more tolerable rate rather than the 5 or 10% or higher some are reporting. This is not his or TRA fault as I understand it is the responsibility of tire company representatives to TRA to present and review technical matters.**
You might drop over on Tireman9 and ask him your questions.
Tireman9 says;
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
