rhagfo
Oct 24, 2013Explorer III
You don't state if you want new or used TV. Based on the TV you purposed and 04 to 08 Ford F350, you are likely looking used. Unless you have a solid history on the Ford 6.0, I would be looking at a DuraMax of Ram. Used that age you will likely need to get a dually to be within the numbers. If fully loaded to the 16,000 GVW pin can be an easy 3,000 to 3,200#.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
