Michelle_S
Oct 25, 2013Explorer III
First off, take that hitch weight and forget it, you'll more than likely be running between 3500 to 4000 with a 5 slide unit. Our unit is 40' 4" with a gross of 16.5K and only three slides and runs a pin weight of 4K (has an onboard genny). So to really fall within specs you will probably need one of the newer Diesel Duallys to be able to handle the pin weight and control that beast. Any Diesel can pull it, but most won't be able to carry the weight.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
