AdamBryner2012 wrote:
Hello,
Can someone tell me what size truck I need to pull this 5th wheel comfortably?
Would a Ford F-350 SD XLT SuperCab Long Bed 4WD with a 6.0L V8 OHV 32V TURBO DIESEL handle it?
We want to be able to head out west.
Thank you for your suggestions!
So the spec's look like a three axle toy hauler???? Will you be towing at near the trailers GVWR?
If this is not a three axle TH(with 5 slides it is maybe not a TH), then the tires noted just barely cover the axle weight and it needs an upgrade to LRG 16" tires or 17.5 rims and tires, or you will be back shortly with a failed tire thread!
So you should think about replacing the 235/80R16E tires with more reliable tires. That size is noted for problems time and again. Do that in the deal before purchasing!
Tell us more about the trailer and your plans.
As many have pointed out, you are generally better off staying away from a 6.0 Powerstroke. A 2006 or early 2007 Classic Duramax/Allison dualie would be a good choice with the LBZ engine. No LLY from 2004.5/2005 because many over heating problems. Or a 2005-early 2007 5.9 Dodge/Cummins with a manual tranny and exhaust brake.
Chris
