I recently bought a King of the Road 36ft 5th wheel. It is a triple axle, and weighs about 13K. What size truck should I realistically be looking at getting to pull it?
Assuming your 13K weight number is a dry weight. The newest round of 350/3500 SRW will handle it if you watch your pin weight. If you buy a newer dually, then you will not have to worry about it.
Are you sure on that weight is the big questions. These were big heavy trailers that needed three axles.
