4x4ord
Jul 30, 2018Explorer III
theoldwizard1 wrote:donn0128 wrote:
Get a 1 ton.
The new price difference is minimal, and used you can probably get it cheaper than a three quarter ton.
1 ton (F350) ride a lot rougher, especially when empty, than a 3/4 ton (F250).
I don't think so.... Unless they've changed things in the new model, the only difference between the HD 3/4 ton and the 1 ton SRW is that the 1 ton gets an overload spring and spacer block on the rear leaf and a different door sticker (permitting 1500 lbs more payload) This overload spring only comes into to play when you are loaded quite heavy, as in when you hook on to a 5th wheel.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
