Glen_Schumann
Apr 28, 2008Explorer
CAT Scale Weights: (scale weight, rating)
with FW hitched
TV Steer Axle 4,400, 4,670 (under by 270)
TV Drive Axle 5,280, 6084 (under by 804)
TV total 9,680, 9,200 (over by 480)
Trailer Axles 8,000, 10,050 (under by 2,050)
Gross Combination weight 17,680, 22,000 (under by 4,320)
TV only
steer axle 4,400
drive axle 3,460
total 7,940
Thus Pin weight is 1,820, FW total weight is 9,820 and pin weight is 18.5% of FW total weight.
All water tanks empty (fresh, both gray and black)
LP tanks about 2/3 full
FW loaded for travel
Fuel tank full
TV loaded for hauling
Myself, DW, 5 yr old grandson
There was 50-75 lbs of firewood in the TV box which will not be there on most trips and I am beginning to think I have more leveling material than I need. This can probable be reduced by another 50 lbs.
There is plenty of room in FW GWR and CGWR to fill the fresh water tank (about 320 lbs) which will take weight off the pin as it is at the very back (is 200 lbs reasonable?)
I do plan to have a pin box bike rack which when fully installed and with max load should be about 150 lbs. There was also some cargo in the FW which could be shifted to the back end. I am figuring we can get to within about 200 lbs. of TV GVWR with the adjustments.
I think I am comfortable with that. Your comments are welcome.
with FW hitched
TV only
steer axle 4,400
drive axle 3,460
total 7,940
Fuel tank full
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
