sirdrakejr
Jun 19, 2008Explorer
Yes, In KGs. But that is ONLY axle weights NOT GVWR which includes the weight on the hitch. The GVWR ( 1775 ) given is the number you pay attention to. The GAWR is the absolute maximum for the axles at 32# PSI tire pressure. If the hitch weight is about 12 percent of the GVWR then the actual axle load you should expect to see when you are ready to travel is about 1560 KGs, which is about 80 percent of the GAWR. That is about right.
Frank
Frank
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
