BillandCarole
Jan 22, 2009Explorer
DW-gray wrote:
Today I weighed the TV and RV. The RV's fresh water, gray water and black water tanks were filled with water to maximum. I also filled the RV gas tank. By my calculations the fluid weight should be about 2,412 lbs. I doubt I'll ever come close to that weight while traveling but was enough to give me a guideline. Here are the measured weights.
TV + RV
TV Front: 4,580 lbs. (620 lbs. under GAWR)
TV Rear: 7,560 lbs. (1,790 lbs. under GAWR)
TV Total 12,140 lbs (60 lbs. under GVWR)
RV 12,460 lbs.
GCW 24,600 lbs.
Pin Weight: 4,100 lbs.
I also conducted a braking test per the California DMV code. In a nut shell, the code states that my type of vehicle combination should stop within 40 feet from the speed of 20 MPH. Although this was unscientific, I was sure I stopped less than 20 feet.
I want to compliment you on paying attention to your GVWR. This always seems to be the most critical, limiting and exceeded limitation. In reviewing this thread, I can not but help to note the many rigs that far exceed this limit. Exactly how critical it is I can not say exactly, for I know that I have unknowingly gone several hundred pounds over it for some quite long distances without incident. However there is always that all too important "sh*t" moment when it does. And then there is always the ever-present possibility of the legal implications if there is an "issue".
Regards
Bill
About Fifth Wheel Group
