Brad_NSW
Mar 01, 2009Explorer
Here's my numbers for Dodge Ram 3500 SRW
Montana 5th wheel
Cab mounted boat/motor (see signature picture):
In the Cab: Wife, dog and fishing poles
Gross Veh. Wt Rate Rated: 9,900/Loaded 10,120 (over by 220lbs)
Gross Ax Wt (front) Rated:4,750/Loaded 4,460 (under by 220lbs)
Gross Ax Wt (front) 4,220 Empty (Diff-240lb - wife, dog, boat)
Gross Ax Wt (rear): 6,150/Actual 5,660 (under by 490lbs)
Gross Ax Wt (rear) 2,940 Empty (Diff-2,600 tounge wt+120 boat/motor)
Gross Comb Wt Rate: 19,000/Actual 21,000 (over by 2,000lbs)
Trailer Axle Wt: 10,880lbs
Trailer Wt: 13,480lbs
Tounge Wt: 2,600lbs (19.3% of trailer wt)
With the Pac Brake, the 2,000 over on GCWR doesn't seem too bad. Thoughts??
Handles grades up and brakes down just fine. Hit a turn out on a down grade today and it was WAY too short, braked just fine and the sports cars piled up behind us went on their merry way.
Montana 5th wheel
About Fifth Wheel Group
