ramcneal
Oct 16, 2009Explorer
B W M wrote:
YES your fifth wheel is mounted to close to the cab. See if your fifth wheel is a adjestable.If so you need to move it back from 1 to 2 inches. 1 might do it for you.== GOOD LUCK Here is my truck frunt 5.160 Both 12.160 truck trailer 28.200+ both trailer axles 10.880
His 5th wheel might not be located to close to the cab. He should weigh his truck when empty to determine if the 5th wheel is adding any weight to the front axle. My truck (Dodge 2500 Cummins quad cab 4x4) weighs in around 4500lbs on the front axle without the trailer which is not much lighter than his truck.
About Fifth Wheel Group
