Glen_Schumann
Mar 30, 2011Explorer
soling2003 wrote:
Thought I might as well add mine here too,
2010 F250 CC long, 6.4 diesel, long bed 4x4 with hitch, wife and full tank of diesel - tires are rated at 3750 lbs.
Truck only - Front axle - 5240
Rear axle - 3540
With Grand Junction 35TMS pretty much fully loaded -
Dry weight - 12840
Dry pin weight - 2273
GVW - 15500
Truck front axle - 5260 - rated at 6000
Rear axle - 6300 - rated at 6100
Trailer axles - 11540 - rated at 14000
pin - 2760
GCVW - 23100 - GCVWR 23000
I Know, I know, I am finding myself a few hundred pounds over here and there. We took a trip across a few mountain passes here in Wa and OR with no issues going up or down. Probably upgrade to a Dually one of these days.
What is the GVWR of your truck? Hitched you weight as shown in your post is 12,100 lbs. The number I found for an F250 GVWR is 9200 lbs. If that is accurate you are nearly 3,000 lbs over your GVWR when hitched.
About Fifth Wheel Group
