DW-gray
Sep 19, 2011Explorer
The_Roberson's wrote:
I was reading all this on "real weights? Truck and trailer". I have been pulling 5ers for a very long time, and this topic had me go and weight my truck and trailer on the CAT scales before our last camping excursion and this is what I found. My truck is a 2008 RC 3/4 Silverado with a 6.0 and a 3.73 rear end. My trucks FT Max axle weight is 4200 lbs. and the RR Max are 6084 with a Max GVWR of 9200 lbs & a GCWR of 16,000 lbs. I pull a 2011 MK2900 Sundance thats dry weight is 9200 lbs.
I went to the scales and here are the results with me in the cab and everything loaded in the 5er to last 2 weeks with 47 gals of water, 1 half full and 1 full 30 lb tanks of LP.
STEER AXLE 3700 LBS
DRIVE AXLE 5220 LBS
TRLR AXLE 8260 LBS
GROSS WEIGHT 17180 LBS
That means that I am over 1180 lbs on my GCWR for my truck. All the other numbers were good. It pulls like a dream and is real stable. My truck is not under an warranty any more. Just curious if you think I am going to damage something pulling a little over 1K more than recommended?
Thanks!
I re-posted this as a question and not for infomation. Sorry!
As long as you feel comfortable with your rig's towing and stopping, I wouldn't be concerned at all. If you have ever felt unsafe towing your trailer, then you may consider a bigger truck or lighten your load.
Drive safely.
About Fifth Wheel Group
