Cummins12V98
May 20, 2013Explorer III
JohnBoyToo wrote:
for those that might be interested:
2013 Ford F-350 Platinum, 6.7 diesel crew cab shortbed single rear wheel with 11,500 gvwr with superglide 18k hitch, ford's truxport roll up bed cover, factory toughbed sprayed bed liner, pkg 618A, moonroof, wheel well liners...
(all listed to give you an idea of options weight)
cat scales with full 26 gal tank, me. the wife, and the dog:
steer 5040
drive 3660
total 8700 - a fat one :)
will be adding a rear sway bar today so that should be a bit more...
so that leaves me 11500 - 8700 = 2800 carrying capacity..
on edit:
Now I need to weigh truck and rv together to see if it is > the 23500 gcwr...
or steer axle weight is > FAWR of > 6290
or drive axle weight is > RAWR of > 7180 (7180-3660=3520 if all on backend:))
or total of steer axle + drive axle from scales with rv attached is > 11500 ...
You probably won't even add 100# to your front axle loaded. With 4,500# pin weight of that only 100# goes to my front axle. I have my B&W hitch full forward.
Why do you need sway bars? Are you going to haul a slide in camper?
About Fifth Wheel Group
