DW-gray
Feb 08, 2015Explorer
flyairam wrote:
I only have truck weights for now, my ordered Arctic Fox fifth wheel hasn't been delivered yet:
2006 Dodge 3500 Laramie 4x4, SRW, quad cab, short bed. It's equipped with a PacBrake, Vision 19.5 inch wheels, and 90 gallon in-bed transfer tank.
The truck was weighed without driver but all 125 gallons of fuel capacity topped off and the Superglide hitch mount installed. The actual hitch was not mounted, it weighs about 200 pounds.
Steer Axle: 4580
Drive Axle: 3500
Gross Weight: 8080
Hmm... If your truck's GCWR is 23,000 lbs. and the GVWR is 9,900 lbs., that doesn't leave you much available payload to tow a fifth wheel. According to RV Tow Check, using those numbers, your fifth wheel tow capacity could be just 9,100 pounds.
About Fifth Wheel Group
