rhagfo
Aug 16, 2015Explorer III
Garyl53 wrote:
F250 6.7L PSD 4X4 Lariat - Full tank, Husky 16k W hitch, me:
Steer Axle - 4720
Drive Axle - 3300
Total - 8020
With 2007 Keystone Challenger 29RKP under tow:
Steer Axle - 4740
Drive Axle - 5980 (vehicle total=10720)
Trailer Axles - 7780
Total - 18500
Trailer:
Pin Weight - 2680
Axle Weight - 7780
Total - 10460
About 700 over published tow vehicle GVWR (10000) but...
1320 under tow vehicle axle ratings (FGAWR=5940 + RGAWR=6100 = 12040)and...
5000 under tow vehicle GCWR.
Chucking like hell and still haven't figured it out:( Hitch is tight and moves only 1/8" when locked onto king pin. Maybe pin weight is too heavy at 25.6%? Seams unlikely but I will try to shift some things to the back (or unload the garage) just to see if it helps.
Simple fixes for chucking!
#1. Very good shocks on the TV, we run Bilstein 5100's
#2. Get the 5er as level as possible.
#3. Put shocks on the 5er, if you question this watch it in the mirrors next time you hit a bridge transition.
I doubt if pin is too heavy, a bit on the high side, but I run with my fresh water tank full, as it is just forward of the axles, helps smooth the ride some.
About Fifth Wheel Group
