juzplanekrazy's avatar
Sep 12, 2007
Whats Your Real Weights? Truck and Trailer. The Real Deal
I don’t know if it’s been done before or not but I was thinking about keeping a running list of real truck weights by year and type, and trailer weights by brand, size and what the total combined weight is of each guys rig. I was hoping the info would be a help for guys wondering about what the real weights are for a certain type of truck and to keep track of the more popular brand 5th wheel trailers. Another thing that will come out of it will be to see just how many guys really know what they are towing and if they know what their weight capacities are.
I’m sure it will take some time to compile a list and it will grow as guys add there info but I’m hoping it will help the newer guys in the long run to be directed back over to this thread in the future.
I’ll keep the TV lists to mainly the big 3 and from ¾ ton and up and I’ll try to keep the 5ers in a group by real GVW, length, and then manufacture. Any ideas are welcome as long as it makes things easier. And only real information can be given, so no guessing allowed. Only guys that have scaled there rigs or are totally certain of the weights.
Let’s see if I can keep the format real simple to type down and that will make it simpler for guys to refer back to and to keep track of.
Here we go……
TV - 2006 Dodge Mega Cab 3500 4x4, real scaled weight with full fuel, hitch, DH-DW and misc. gear = 7,500lbs. TV GVWR is 10,200lbs
5ver – KZ New Vision TH 38ft 14,500lbs loaded GVW. GVWR is 18,000lbs
Normal running TV & TH GCW weight= 22,500lbs, TV GCWR is 23,000lbs
Real Wet Pin Weight=2,950lbs
  • 2004 2500 QC CTD 4 passengers, fuel, tools 7700#
    2004 305bhs "dry spec" 8080# actual w/60# propane, 25gal water, +"stuff" 10,000#
    pin 1400#
  • 2005 CHEVROLET, 2500HD, DURAMAX, EXTENDED CAB, STANDARD BOX (6.6)
    ACTUAL TRUCK WEIGHT, WEIGHTED 9/9/2007, FULL TANK OF FUEL, MYSELF (240LBS), SPARKY (50 LBS), TOOL BOX, AND 5TH WHEEL HITCH.
    FRONT AXLE = 4200 LBS
    REAR AXLE = 3040 LBS
    GROSS WEIGHT = 7240
    CAMPER INFORMATION STICKER located on sticker inside glove box.
    CARGO CAPACITY = 1851 LBS.
    GROSS VEHICLE WEIGHT RATING = 9200 LBS
    :B
  • TV - 2004 Dodge Quadcab 3500 SRW, real scaled weight with full fuel, hitch, DH-DW and misc. gear = 7,240lbs. TV GVWR is 9,900 lbs
    5ver – Alfa Sun SF30RL 32ft 12,440lbs loaded GVW. GVWR is 15,500lbs
    Normal running TV & TH GCW weight= 19,680lbs, TV GCWR is 23,000lbs
    Real Wet Pin Weight=2,160lbs
    I have added Timbrens to help the loaded ride and keep the truck level. The stock tailgate is replaced with a Stromberg-Carlson flow thru gate. Running boards and tailgate are equal to the same weight of the stock tailgate.
    Frank
  • Just found out mine, trying to find where the weight is.....
    TV 2007 Chevy CC D/A 4wd Dually with hitch, full of fuel, toolbox, 2 adults, 2 children, and dog. 8240lbs
    5th Wheel -2007 KZ Sportsmen Sportster 37KGX3 - sticker weight dry 11,556. Sticker GVWR is 16,940. Actual scaled weight with all our clothes, food, etc and a golf cart, DRY!, 19,120. Sticker hitch weight 2940, actual 3520. I don't see a problem here. Looks normal. However the total weight on the axles is 15,600... that's 1,600 over the axle rating and 600 over the tire rating. I am at a loss. I hope it is scale error. I will be reweighing this weekend.
    Total GCWR 27,220!!! Truck rated at 23,500. I have no idea where the weight is. I can only hope that the scale was wrong. We did not load 7500 lbs of gear in here. Not to mention the fact that all tanks were empty and I have a 110 gallon fresh tank.....
  • TV: 2006 Ford F350 Dually CC, 4X4 with the Tow Boss package.
    GVWR is 13,000lbs, GCWR is 26,000lbs.
    CAT scale says 8360lbs. This is with full fuel, 5th wheel hitch, 50lbs in tools and no passengers.
    Trailer is a 2006 Weekend Warrior, LE3905 model. 40' total length. GVWR is 16,000lbs.
    Empty weight on the way home from the dealer is 11,600lbs with 2680lbs of pin weight.
    Fill the trailer with water(150gallons), food, 2 kids quads and my sand rail, trailer weighs 15,960lbs total with 3400lbs of pin weight.
    Total going down the road is 25,980lbs with the trailer loaded and passengers in the truck.
  • TV- 2005 Ford F-250 SD extended cab SB Lariat, 6.0 diesel, 2 people & full fuel, scaled weight #7710; GVWR= 9800. scaled weight with PIN= 10200
    5er= 2007 Montana 3000RK 35 ft, GCWR #12560, actual weight #10850; listed pin weight #2160; actual pin weight #2495.
    Normal running TV & FW; GCW #17560; GVWR # 23000.
    New!!! 2008 F-350 Super Duty Lariat, Diesel, Extended Cab, Short Bed, SRW.
    GVWR #11200, Front Axle #5600, Rear Axle #7000
    Actual scaled weight with full fuel and one occupant. GVW #7940, Front axle #4800, Rear Axle #3140
    Correction!! The listed GCWR should have been GVWR of #14160 on the 2007 Montana as taken from the sticker inside the 5er.
    The listed GVWR of #23500 should have been GCWR of #23500.
  • TV - 1999 Volvo 610: real scaled weight = 18,260; GVWR = 80k
    fiver - 2005 Newmar Mountain Aire 35 BLKS: 15,120 dry; 17,200 loaded;
    GVWR = 20k; real wet pin weight = 3,580.
    add the smart fortwo and total running weight = 36,860
    Some variance as the Volvo carries 300 gals of fuel.
  • TV - 2000 Ford F250 SD Super Cab 7.3 PSD, real scaled weight with full fuel, hitch, DH-DW and misc. gear = 7,640lbs. TV GVWR is 8,800lbs
    5ver – 2007 Keystone Laredo 29RL 32ft 9,160lbs loaded GVW. GVWR is 11,000lbs
    Normal running TV & FW GCW weight= 16,800lbs, TV GCWR is 20,000lbs
    Real Wet Pin Weight=1,820lbs
