Second_Chance
Feb 13, 2017Explorer II
On conventional towable suspensions (solid axles, leaf springs), the only alignment that can be done - on some rigs, but not all - is to make sure the axles are parallel and perpendicular to the center line of the trailer. The individual wheels are not adjustable for caster, camber or toe. If you have tire wear issues on one tire, the spindle/axle will have to be replaced. A truck/trailer alignment shop with Hunter equipment can check your alignment - but they may not be able to do anything about it. If you're not having problems, don't worry about it.
Rob
Rob
About Fifth Wheel Group
