pcm1959 wrote:
When using the EZ Lube feature, you will know if its a success when you tow your rig the first time after using it. Braking performance will be the clue as to whether or not the rear seal was blown. For that reason, I had pack only. Just my 2 cents. Phillip
Okay folks, I had to pull out the owners Manual. I only want to present the Facts. So here it is:
ULTRALUBE
1. Remove the rubber plug from the grease cap.
2. Insert grease gun on the grease zerk.
3. Pump until new grease begins to appear.
4. Replace rubber plug.
Not all wheel bearing grease mechanisms are the same. I guess reading your owners manual is the correct thing to do. So after getting conflicting information, I dug mine out and read it. I M fairly confident I did the correct thing.
