93mastercraft's avatar
93mastercraft
Explorer II
Jul 02, 2013
Wheel bearing Grease
How often do you check your wheel bearings? This weekend I had to replace one of my tires, so I decided to check the wheel bearings. Mine have the hub caps where the entire rim and tire have to be removed to access the grease fittings.
I was surprised at how much grease I had to pump in. On a triple axle I went through two tubes of grease. I pumped enough grease into each until I saw the grease come out the front. Do manufactures not fill these things up w/grease?
  • slarsen wrote:
    This is one of those topics that will bring out strong opinions about how you need to disassemble and clean the bearings annually, and if you use a grease gun you'll blow out the seals at the back.
    Here is my opinion: I use a grease gun, but I am cautious about how much grease I give the fitting. I give each fitting two squirts, then the next day another two squirts, and so on, so the grease can migrate and take off any pressure from the seal before it can start to leak. When clean grease appears, I'm done. It has worked for me, and I've pulled my trailer 20K miles over three years. Another option is to grease slowly while rotating the wheel. For sure, you want to hand-grease, never power grease, and I'd say it should always be done in warmer temps, not in February, so the grease flows well.
    BTW, the quality of the grease is very important. I don't recall the specs and I'm far from home, but you can't buy too good grease. There is a Lucas Oil place in my town, and I buy the best they have for wheel bearings.
    Yes, I am with you on the whole blowing grease out the rear seal. At first I was very concerned about that. But I have greased a lot o wheel bearings in my time. If you own any farm equipment and trailers, U will know what I mean. But I did not feel any resistance while pumping the grease in. In fact, the dang things did not seem to have any grease at all. I knew I needed to pump until I saw grease come out the front. Yeah, the axles on this camper are 6000 lbs each. So, it has some pretty huge hubs and I suspect pretty good sized bearings, but I have never took a hub off this, so I cant say. All I do know is, It is better to have grease than no grease. Hopefully I avoided a huge disaster. I have seen others stranded on the side of the road with the axle on the ground. We all know what happened there.
  • This is one of those topics that will bring out strong opinions about how you need to disassemble and clean the bearings annually, and if you use a grease gun you'll blow out the seals at the back.
  • Sounds like a lot of grease. When I do mine, I just do a couple of shots in each wheel. (Mine are different than yours, I don't have to remove the wheel.)
    I am curious as to what others will have to day.
