- Cummins12V98Explorer IIIIf you are saying you have 7K since new I would HIGHLY advise a repack with QUALITY grease, new seals and adjust the bearings.
- ScottGNomad
Ed9824v wrote:
when you say repack does that mean flushing in solvent and renewing the grease for the inside and outside bearings.
Yes.
And it does not mean using the zerk fitting.
These same kinds of bearings were used on cars for many decades. The bearings went 50~100K miles between brake jobs and held up fine.
So I quit messing around with them every year. When ever I did so, I could see it wasn't needed.
With that in mind, I let our last TT go about 40K before repacking. Even then it was a waste of time and totally unneeded.
The yearly suggestion is CYA stuff from the manufacturer. - Ed9824vExplorerwhen you say repack does that mean flushing in solvent and renewing the grease for the inside and outside bearings.
- I will pull the wheels every spring and check out the bearings at a glance.. I repack every 2 years depending on the miles towed the year prior....
- Ed9824vExplorerI would think if you have been in water crossing condtions it may be necessary to do more ofter water tend to get sucked in as it cools down the bearings.
- fj12ryderExplorer IIIIf the bearings are full of grease and in good shape, every 3-4 years is plenty often IMO. But if you're traveling 15,000+ miles per year, I'd check every 2 years.
- MFLNomad IIManufacturers say every year/12k miles.
IMO, it is wise to pull hubs, pack bearings/check brakes right away upon purchase. Once properly done, I would not worry about bearings for at least three yrs, or 30K miles. Lots of OPINIONS on this subject, and they do vary. :)
Jerry - LwiddisNomad IIIMiles is one criterion, Fox. Time, rain, ice/snow/salt and dirt road driving are some others.
- donn0128Explorer IITypical repqck recomdentation is once a year
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
