I just had my 5er, 2009 Silverback, 35ft, at the repair shop. I had the never lube bearings replaced with new ones. A little over 25,000 miles on the old ones. When my trailer guy pressed out one of t...
They should/WILL last alot longer than 25,000 miles.......
THIS.. You do know that the only way to press them out is by using the inner race because of the way the retaining lip is machined in the back of the hub, so you can destroy the bearing getting it out. If they were installed by using the outer race to push them in
Could have been the issue for them "falling apart".
