d-mac1's avatar
d-mac1
Wheel Bearings
Haven't done any trailer wheel bearings in a while and thought I'd best grease mine Saturday. I can't remember, do I need to remove the seals in order to get the bearings out? I'm thinking so but wanted to get confirmation. Presuming so, that means I need new seals.
They're 6k Al-ko axles which I'm thinking would take a standard size seal, right? Anybody know the size?
Thanks.
  • BobWanderer wrote:
    lincster wrote:
    I always take a hub off, take it with me and have them match up the seal. Safest way to do it.
    After the first time you service the bearings, you keep an old seal or record the numbers for the future.
    X2, If its the same 6k Alko I had on my other toy hauler I have the seal numer in the book in my truck. I'll look tonight for you.
  • I always take a hub off, take it with me and have them match up the seal. Safest way to do it.
  • You would need to know who makes you axle and model. Some axles have tags on them, sometimes it's listed on your specification sheet.
  • How can you look up what size seal you need with out taking one out?
  • ScottG wrote:
    jfkmk wrote:
    I did my bearings this spring. Definitely buy new bearings before you tackle the job. They're cheap and you don't have to worry about destroying the old ones taking the rear bearings out. They're all different sizes, so look up in your manual or on-line which size you need.
    By "bearings" do you mean Seals?
    I hope so, no need to replace the bearings every service.
    If they are blue, rusted, galled or have the plating flaking off then by all means change them.
  • I did my bearings this spring. Definitely buy new bearings before you tackle the job. They're cheap and you don't have to worry about destroying the old ones taking the rear bearings out. They're all different sizes, so look up in your manual or on-line which size you need.
  • Front bearing, don't need to remove a seal.
    Rear bearing, yes, need to remove a seal.
    I would plan on all new seals cause normally when you remove it, you destroy it.
