3Fivers51 wrote:
I still wonder how the chocks on the ground do work, I guess I wonder what keeps them from slipping on the ground as well.  Anyway, does anyone have a picture of their wood chocks?  I would like  to use some of the wood I have around my house!
Thanks,
Bill
Chocks work because they are a wedge.  They can slip on the ground, especially if they are on gravel or other loose base.  But if the angle is correct they will lock in pretty good.  Some chocks you can purchase have an angle that is too steep in my opinion.  Those Harbor Freight chocks are too steep, again in my opinion.  And of course the diameter of the tire plays a part too.  Those HF chocks are a better fit for semi truck sized tires.  I'm sure they work for RV's too, and a good thing about them is that they have a lot of weight to them.
I've never purchased chocks, just cut a wedge out of scrap lumber.  I carry a couple of different styles, and have had others in the past too.  Lately I've been using the ones pictured below.  It is sized just right for between my current trailer tires, and it can work in either direction, and if I've mis-judged the slope of the land it will still work within an inch or so in the other direction.  I also carry a couple of single wedges.  Depending on how bad the slope is on a particular site, I might only chock like below on one side, or I might use this on both sides, and I might even add 1 or 2 of the single chocks if it gets really bad.
I've never cared about a little wiggle in the coach, so don't use expanding chocks or pin stands or any of that stuff.  Just the rear crank down stabilizers, and for short overnights I might not even deploy those.
Even a chunk of firewood makes a decent chock, and I would argue better than X-Chocks, or any of the jack style chocks alone.  X-Chock style stop working if you have a tire loose pressure during the night, and your trailer can roll away while you blissfully sleep.  Not something I want to trust my life on.
