Poppy_s_5th_Whe
Dec 01, 2013Explorer
Wheel/Brake/Bearing Question
Hi All,
I was having some poor braking on our last trip so, after scolding myself for failing to adjust the brakes or lube the bearings since we got the trailer (probably 12,000 miles ago) I decided to adjust the brakes and lube the bearings (I have the E-Z Lube bearings).
I got the trailer jacked and I noticed a lot of play in the wheel. By play I mean that if you have your hands at 12 o'clock and 6 o'clock you can get a considerable amount of wobble out of the wheel. I tried both wheels on the drivers side and they both had play.
I went ahead and lubed the rear wheel first and it took a whole 12.5 oz tube before I got fresh lube coming out. I had hoped that might solve my problem but, of course, no such luck.
I went ahead and adjusted the brakes on both DS wheels but didn't lube the second wheel yet until I find out what my problem is. OR, if it is normal on a trailer to have that much play.
So my questions are
1.) is there normally some play in the wheel on trailers? (I suspect not)
2.) if not, do you think my problem is that I need entirely new bearings? (I suspect so)
I race a corvette and if my wheel has play like that, I need to replace the whole hub assembly as they do not have serviceable bearings.
So my questions are
