- robwhite61ExplorerI level side to side, put front landing gear down, put in chocks, disconnect, level front to back. While I am hooking up the water, sewer, etc. the DW opens the slides and prepares the inside for living. I get done first so I help her finish the inside.
- BusaGuyExplorer
ependydad wrote:
korbe wrote:
The slide goes out after all leveling and disconnecting has occurred. More difficult to crawl under the slide to mess with the wheels. We do however, when checking for level side to side, leave the slide side a hair higher prior to extending. Better than a hair lower for that side.
Same here.
For folks without a leveling system, how would you level AFTER the slides are out? With my dual axles, I have to move the camper a few feet either forward or backward, place the blocks, and then move the camper back onto them. I couldn't imagine doing that with the slides fully deployed...
For me, it seems to work better to level side to side then front to back then open the slides. - ependydadExplorer
Same here.
For folks without a leveling system, how would you level AFTER the slides are out? With my dual axles, I have to move the camper a few feet either forward or backward, place the blocks, and then move the camper back onto them. I couldn't imagine doing that with the slides fully deployed... - Greene728Explorer
downtheroad wrote:
- side to side
- front to back
- slides out
- re-tighten stab jacks on the non-slide side.
Exactly - Rob_FlaExplorerWhen setting up, we run the front legs down and unhook off the hitch / truck.
Press the Level Up Button and wait till it completes.
Open all the slides.
When breaking down, we retract the slides first.
Hit the Level Up Retract Button.
Hit the Level Up return to hitch up position.
Hitch up the Truck. - NJRVerExplorer
Terryallan wrote:
I level, and hookup everything out side before I put out the slide.
X2 - korbeExplorerThe slide goes out after all leveling and disconnecting has occurred. More difficult to crawl under the slide to mess with the wheels. We do however, when checking for level side to side, leave the slide side a hair higher prior to extending. Better than a hair lower for that side.
- TerryallanExplorer III level, and hookup everything out side before I put out the slide.
- HalmfamilyExplorerLevel first. On ours, I have opposing slides and would have to climb under them to add 2x to level side to side if I extended them first. That would be too much of a pain. Front to back no problems.
- old_guyExplorermy manual says level first then slides
About Fifth Wheel Group
