Dtank
Jun 05, 2015Explorer
laknox wrote:Phil Hendrix wrote:
We are purchasing a used/new to us 5th wheel but my 3/4 ton truck is not going to be enough truck to pull the trailer. The trailer is 40' and weighs approx. 14,000 pounds. Previous owner pulled the trailer with a F350.
I was wanting to rent a truck to go pick the trailer up and bring to our home where we will park it till I can do some repair work on it. We are in northern Illinois and the trailer is currently in South Carolina.
Any suggestions where I could rent a truck?
Thanks,
Phil
Phil, I've never seen a pickup for rent with a GN or FW hitch available. You'd likely have to go to a Class 8 to find a rental, then have a CDL to drive it. Like the others have said, find someone to haul it for you or check the unloaded weight of the trailer and use your current truck. I know I probably would, and I have less payload than you do. Take it easy and stop often.
Lyle
The Ryder, etc. HDT (Class 8 tractor) rental (and CDL) is not a viable option!..:(
1. A commercial hitch is non-articulating. Might work OK for the trip, however it may "tweak" the trailer frame.
Most MDT & HDT owners use air ride hitches intended for RVs.
(Won't be available on a rental tractor)
2. Properly licensed, you are driving a *Commercial* tractor, subject to Commercial rules and regs - both State & Fed.
Stop at scales and either convince the LEO's you are not for hire, towing a private RV etc. - and/or pay some serious fines.
A NON-Commercial Class A - won't work either.
You rented a commercial tractor from a commercial operation.
The best option is what others have suggested:
Find an RV delivery ("hotshot") driver. (Or use your truck)
Most 5th wheel deliveries originate in Indiana (LOTS of 5th mfgrs there), and head out to the various states.
A paying return trip is a *bonus* for the drivers..;)
Thoroughly check (replace as necessary) tires & wheel bearings before departure.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 27, 2025
