- Second_ChanceExplorer II
djousma wrote:
I cant give you a specific answer, but if you turn it on, and follow the sound, you should find it. sometimes in cupboard under the sink area, sometimes in other cabinet.
X2 ^^. I've seen a number of fifth wheels of different manufacture with the water pump in the "utility" area behind the front storage compartment under the bathroom. Often, there is a thin panel separating the "basement" from this utility area which contains the water heater, main heater, water pump, etc.
Rob - djousmaExplorerI cant give you a specific answer, but if you turn it on, and follow the sound, you should find it. sometimes in cupboard under the sink area, sometimes in other cabinet.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
