Smoke90's avatar
Smoke90
where to get Suburban range part. Stove quit working
hi to all,
last weekend I was not able to lit the stove on our Suburban range in our Cyclone toy Hauler.
I think it is the thermostat that must be replaced
where do you guys buy replacement parts?
I did some search on the forum and I am surprised no one ever post about this. As I ll be surprise that no one had to change the pilot on their stove
thanks
  • GO HERE
    Look up your Model of Suburban
    Then you can identify part and have a part number to search Internet for it
    Can't get pilot to light .... oven knob on pilot position and pushed in?
    Can't get main burner to light off using BBQ lighter/hot thermocouple?
    Suspect oven safety valve (oven gas valve)
  • D.E.Bishop wrote:
    The thermocouple has nothing to do with lighting the pilot. If you can't even get it to light while holding a match in front or under it, there isn't any propane getting there. Lots of posts regarding purging the system of air in order to light.
    I agree with purging the air, but why are the top burner working while I let it open for minutes and minute and the oven still not lighting?
    also I thought that if I keep the thermocouple hot (whith a BBQ lighter) and turn the knob ON the main burner will lit?
  • The thermocouple has nothing to do with lighting the pilot. If you can't even get it to light while holding a match in front or under it, there isn't any propane getting there. Lots of posts regarding purging the system of air in order to light.
  • yes I am pretty sure it is the thermocouple as the pilot does even want to lit
  • If your stove would not remain lit I would think the thermalcouple first. They are cheap and easy to replace. Try that first.
  • Most local dealerships can get the parts you need. I'd also check campingworld.com and www.pplmotorhomes.com too.
