ijon1ExplorerNov 01, 2019Where to jackHi, I am going to change all four tires on my Fury 2910 toy hauler. My question is where should I place the jack and jack stands?
12th_Man_FanExplorerNov 01, 2019According to the axle mfg you should use the frame in front and behind the wheels.I use a jack under the axle where the springs are bolted to the axle. I also use a board between the jack and the axles.If your axles are on top of the spring pack you don't need the board.
Related ContentAtwood Electric Jacks - Replacement ElectronicsJackJack Failure DisasterLeveling Scissor JacksJacking For Tire Change
