La_Gasser's avatar
La_Gasser
Where to place jack to change tire on Toy Haulers?
I have a 2017 Jayco 310W Toy Hauler. I was wondering where do you place the jack to lift the tires off the ground - under the axle or under the trailer frame? I will probably be changing the tires soon and want to make sure the dealer places the jack at the correct place.
Thanks
  • Howdy!
    If you have auto leveling system why not use that to change a tire?
    "Happy Trails"
    Chiefneon
  • Frame.
    With a triple axle, I only let Discount do 1 side at a time.
    When you jack up both sides on a triple axle, the middle axle does weird stuff and flips the shackles around.
    Most 16 year old kids at tire shops don't know how to handle that, so I tell them to only do 1 side at a time.
    Dual axle, lift the whole trailer at once, no problem there.
  • Lwiddis wrote:
    I prefer a ramp on the other tire on that side. Home built with a 2x6. Works fast. I would require tire shop to use my ramp.
    So do you think their insurance would cover them working with your ramp?
  • Most tire store will place a jack under each spring mount and lift the whole trailer at one time. That's what they did with my trailer.
  • Jacking under the spring perches works fine for me. The last thing I would want is someone lifting one side of the trailer to change tires. Jack the axle high enough to change the tires and you're good. Just don't jack anywhere but where the springs are attached to the axle.
  • I prefer a ramp on the other tire on that side. Home built with a 2x6. Works fast. I would require tire shop to use my ramp.
