- chiefneonExplorerHowdy!
If you have auto leveling system why not use that to change a tire?
"Happy Trails"
Chiefneon - lincsterExplorerFrame.
With a triple axle, I only let Discount do 1 side at a time.
When you jack up both sides on a triple axle, the middle axle does weird stuff and flips the shackles around.
Most 16 year old kids at tire shops don't know how to handle that, so I tell them to only do 1 side at a time.
Dual axle, lift the whole trailer at once, no problem there. - Sprink-FitterExplorer
Lwiddis wrote:
I prefer a ramp on the other tire on that side. Home built with a 2x6. Works fast. I would require tire shop to use my ramp.
So do you think their insurance would cover them working with your ramp? - naytherExplorerunder the spring perch is how i've always done it.
- corvettekentExplorerMost tire store will place a jack under each spring mount and lift the whole trailer at one time. That's what they did with my trailer.
- fj12ryderExplorer IIIJacking under the spring perches works fine for me. The last thing I would want is someone lifting one side of the trailer to change tires. Jack the axle high enough to change the tires and you're good. Just don't jack anywhere but where the springs are attached to the axle.
- Colo_NativeExplorerX2 on the ramp or the frame. I got this from Lippert
- LwiddisNomad IIII prefer a ramp on the other tire on that side. Home built with a 2x6. Works fast. I would require tire shop to use my ramp.
- George_HExplorerUnder the spring mount on the axle!
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
