RCMAN46 wrote:
agesilaus wrote:
I would avoid Reese, they have many more reports of problems whereas I have never seen a report of a problem with B&W or Pullrite. As someone who went to engineering school and is basically conservative I would not buy an Anderson.
I have only seen two hitches on this site that have actually failed. One was a B&W and the other was an Anderson.
There have been reports of Reese but no actual hitch failures. Most common problem is high hitching and disconnecting the hitch. Both I would consider operator error.
There are probably more Reese hitches by at least a factor of two than all other brands combined. As such there will probably be more reports of problems.
Maybe a little background on those "failures":
The Andersen deformed under heavy braking but was still usable.
The B&W hitch "failed" when the truck and 5th wheel rolled over. Kind of like your radiator fails when you hit that tree head-on.
