shadoow wrote:
we've had it about 5 yrs. Came with a 2 yr. warranty and we had only minor issues in that time. In the 3-5 yr. range we've the following issues:
- delamination of chinese tires
- battery charger stopped charging
- sealed bearing failure resulted in us replacing both axles
- leaf spring failure.
-Many trailers use Chinese made ST tires, some of the Marathon's that come on Arctic Fox would be (and some aren't). The key is not Chinese so much as "cheap", some lines use really cheap ones.
-Do you recall the charger brand? I thought Forest River used Progressive, same as Arctic Fox.
-Do you know the brand of axle?
