CALandLIN wrote:
Sometimes RV trailer manufacturer’s (especially Keystone) build tandem axle trailers with very little spacing between the axles. Often so close, larger diameter tires cannot safely be used as replacements.
In this case there is a new 15” steel cased ST tire on the market. It’s the ST225/75R15 LRF. It has a load capacity of 3195# at 95 PSI. Its physical dimensions are the same as the OPs OE tires.
Who makes a wheel that is rated for a LRF 15" tire? Oh, yeah those new 8 lug 15" wheels. 2830 seems to be the highest rated 15" trailer wheel. Steel wheels are even less at 2600. Source Tredit, a major trailer tire and wheel supplier. Chris
