valhalla360
Oct 06, 2017Navigator
WTP-GC wrote:
Why does Lippert allow someone so incompetent to respond to critical warranty related questions? First, he claims that he cannot affirmatively state it would void your warranty, but then he says Lippert won't be able to "assist". What exactly does that mean? He states that "if" the adapter causes damage, then you'd be out of luck. And do I read correctly that he's stating you can use the Reese Goose Box in conjunction with the Andersen UH??? Sure, if you had a lowered truck and a high riding 5er, that might actually work. Otherwise, you'll be so nose high you'd be dragging the rear bumper.
That entire correspondence with Lippert is just confusing and doesn't answer anything. Hooray for ambiguity!
Standard CYA answer. Bottom line is if they decide the adapter was a cause, then you are SOL for warranty repairs. That's a pretty clear answer to me. They aren't willing to say it's OK, so good chance it's not designed for it.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
