RCMAN46 wrote:
Take a look at the distance the head mount is from where the two towers are attached to the hitch base with no cross bracing.
Compare this to most other hitches which have a box structure between the head and hitch base.
So? One issue with a B&W side pieces bending, that I've seen posted about. How about the issue with the upturned Reese handle that has cause unhitching on more than one occasion, when making contact with the bottom of a FW in a turn on uneven ground? I've seen plenty of them cut off or otherwise repositioned to prevent this.
Lyle
