Winged_One's avatar
Winged_One
Which of the following tires would you NOT recommend?
I think I am going to replace my Road Rider ST 235/80-16 E rated tires before we go out west. After weighing the trailer fully loaded, it is putting down about 2750 lbs per tire (on the tires).
What tires would you NOT replace them with from any one of the following LT "E" rated tires:
Goodrich Commercial T/A
Bridgestone Duravis M895
Bridgestone Duravis R250
Bridgestone Duravis R500 HD
Bridgestone R265 5-Rib
Dunlop Rover H/T
Firestone Transforce HT
General Grabber HTS
Goodyear Wrangler HT
Goodyear Wrangler SR-A
Michelin LTX M/S2
Uniroyal Laredo HD/H
As I seem to have an odd size tire (80 series), which would you recommend? 235/85-16 or 245/75-16? Taller or wider? Room underneath for either.
Also, where should they lift the trailer to change the tires? (I cheated and used the lippert to raise the trailer for bearing maintenance).
